It is currently Thu Aug 21, 2025 10:17 am
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Aug 20, 2013 3:04 pm
First name: Philip
Last Name: Marcus
City: Cedar Creek
Zip/Postal Code: 78612
I think you must realize that toothing blades are used for two different tasks. The fine toothing irons sold by the better tool houses like Lee Valley & Lie Nielsen are intended for planing wild grain in wood such as walnut burls and plainsawn rosewood. In this case, the toothed blade will remove a sparse but even layer of wood fibers that can then be smoothed with a regular blade.
Cumpiano/Natelson suggests using a blade scored with triangular saw file for marking every other pass as an aid to seeing where you have passed before. Then you can go back with a regular iron for a second pass, avoiding planing the same path twice, which makes it possible to evenly thickness a wide plate. It also will reduce the tendency to tear out.
There's no reason to buy an expensive fine toothed blade just to make a scratch pattern! Good luck.
PostPosted: Thu Aug 22, 2013 10:20 am
First name: Mark
Last Name: Parkinson
Country: South Wales, UK
I have been working on sharpening my iron, one problem I noticed was the back of the iron is flat, but the front of the iron is not. After trying to fix this by hand and having a tough time along with the bevel losing shape, I ordered a bench grinder and a coarse grit water stone by norton.
My board is similar to the one in the video, but it does not taper
I will take a look at the sharpening video, thanks Todd
PostPosted: Fri Aug 23, 2013 7:51 am
First name: Mark
Thanks Filippo
My bench grinder arrived today
It was immediately apparent that a dressing rod is needed, I should be able grind the bevel freehand with the tool rest I think, then I will create the micro bevel on my 240 grit water stone freehand
I searched for quite a while, but did not find any tips or guides on honing plane irons on a bench grinder
PostPosted: Fri Aug 23, 2013 10:19 am
Bench grinders: Dangerous things, mainly to the Plane blade but sometimes to the user as well. The only thing I would use one for is to take out bad nicks in a blade otherwise for sharpening they certainly aren't necessary.
A coarse oil stone is good enough. You don't need to get the bevel flat. It doesn't really matter if this is convex. What matters is the angle right at the tip/edge of the blade. That edge or the very tip needs to be done with a fine stone. Either an Arkansas, very fine wet/dry or 6,000/8,000 waterstone. You can strop as well. No need for honing guides. Better to learn without them IMO.
Here's one method. I don't use this method but I'm sure it works.
http://www.youtube.com/watch?v=vvTcReENk9g
PostPosted: Sat Aug 31, 2013 9:14 am
First name: Mark
I seem to be going round in circles trying to sharpen this plane iron
Tried different methods, grinder, sandpaper, waterstones
In my latest attempt, I got a straight, fairly even bevel, started lapping the back via the rule trick and now the edge is no longer straight
I am now thinking of buying a lie nielson, veritas or hock iron as this 1950's blade is not being taken great care of
PostPosted: Sat Aug 31, 2013 11:03 am
What do you want a straight edge for? Why are using the ruler trick.? Stop trying to get even bevels, perfectly straight edges. Just get a sharp edge. That's all that matters. Unless your '50's blade has lost it's temper or seriously pitted there's nothing wrong with it. You'll have exactly the same problem with new blades.
PostPosted: Sun Sep 01, 2013 1:32 pm
First name: Mark
I have done as you said Michael, it seems very sharp now
The spruce was warped last night so I have been straightening it hopefully will get it back on the shooting board by tomorrow
Thanks Michael, I became pedantic about the sharpening process. It will take time for me to learn to sharpen to the standards of experienced luthiers.
PostPosted: Fri Sep 13, 2013 12:41 pm
First name: Mark
I am still trying to flatten my wood without luck
Is it necessary for the plates to be flat for jointing?
PostPosted: Fri Sep 13, 2013 7:40 pm
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
Use an old Tormek wet grind wheel when necessary and it really is an excellent tool then a diamond plate, have finished with a Japanese wet stone. After the wet stone blades look really shiny but i'm not convinced they are much sharper than they left the diamond plate. Probably pilot/operator error. :)
PostPosted: Mon Sep 16, 2013 1:26 pm
First name: Mark
No, but it helps not having to apply pressure to keep the plates flat. How thick is the shaving off the plane?
I managed to get the top to pass candling and the plates are being glued together now
The shavings were less than 0.05mm, the minimum measurement on my calipers
thanks all
